BIG4244's build
you are lucky..
at least you didnt have to make the entire engine loom by hand!! :p
HA! brave mofo
great progress so far, wiring is gay!
i gave up messing with my wiring loom for my tvs! i had a strop! :lol:
  • Replies 38
  • Views 5.2k
you are lucky..
HA! brave mofo
Lol yeah rindiesel i had all the loom, even if it has been cut/repaired, luckily I've got elsa wiring diagrams from work so i can just match the colours, usualy i hate wiring!
i
Edited by big4244
small update, fitted the 7j teledials i had and machined down the rear adpters 10mm, il get pics up soon, but having trouble getting the car started, car turns over fine, but no injection or spark? i can hear the fuel pump prime, but not firing, its not the immobilizer as it should fire up for a few seconds and cut out again any ides???
fuel lines wrong way..u change the fuel pump..dodgy coil pack?
na there definetly round the right way, haven't checked the coil pack but will do that tomorow, also have no comunication with ECU
new wheels, 7j teledials with ET 52.3 at front and ET23.3 at rear also got camber shims on order for rear 3degrees lol and also a photshop of the wheel colour
Edited by big4244
looks awesum!
Get the wheels sprayed Neon Green ;)
Nice work!
i like wiring, it's like a massive puzzle! :badgrin:
sits well and looks good but pleaseee don't paint em pink
few things, powerflex front bushes (old standard bushes had tried to pull themselves apart) and camber at the back
looks awesum!
The wheels would look sick neon green!
  • 3 months later...
Right big-ish update, car now runs etc, been for a quick drive in it, all the dash is now in properly, also accuired a seat ibiza axle for rear disc conversion, which I've modfied a flat into so the exhaust wont touch like on my stock axle, will get some pics up later today
j
Edited by big4244
