Mk2 Ignition Coil Wiring
Just got my mk2 ignition system ready for my bike carbs but not completely sure on how to wire up the coil
I'm guessing the green wire from the ignition module goes to the positive and black to the negative on the coil?
Which other wires need to connect to the coil, and also which terminal does the rev counter connect to?
  • Replies 11
  • Views 8k
vw colours are usualy black =ignition .....green= switched neg to coil ...rev counter should go to switched neg
Edited by bort
Oh right okay, so opposite to what I though then?
What do you mean by black to ignition?
And i'm guessing the coil also needs a constant positive from the battery?
Sorry, am rubbish at wiring lol
ignition meening a positive that stays live when cranking but goes dead when key is removed ...........if you was to use abatt poss you wouldnt be able to turn engine off.....if you post pic i can label wires for you
okay, thought it might have been just wanted to make sure
would be great if you could label each wire, pics;
Ignition module wires -
Coil -
someone able to help?
yep wiring codes are 15 = ign
1= sw neg
black being ign
you dont show your ing amp in the pic
This?
just made a new ign loom for mine
the coil has 2x blacks , green , red/black
hall sender has red/black , green white , brown white
that pic you posted is the tci...should have 6 wires ....3 for hall sender , green and black for coil and a earth to the battery
dunno where the other black and red/blk at the coil come from lol
yep it does have those 6 wires
the other 2 wires for the coil are the ones I need to know lol
mainly where the other wire on the positive (15) on the coil goes/comes from
so as I've read for the coil,
on switched neg. 1 = green wire from tci unit, and rev counter
on ignition positive 15 = black wire from tci, and what else?
this right?
same question, can i connect the wires to the multipul one which teh stnadard gt coil runs of
