Removing Boot Lock/handle, 6n
Right, i need to remove my boot lock and handle on my 16v, as the handle has snapped off due to scum knocking it off with a brick, and also to help out the guy breaking his car and sending me a new boot handle.
There are three t25 torx screws that are esily undone, a couple of rods that unclip and then i cant see anything else that can be undone or removed... Its all loose but it just wont slide out of the boot lock recess in the bootlid! It doesnt fit!
If anyone can help me out thatd be great, I'm guessing theres a 'knack' to getting it to slide out!
Cheers.
  • Views 5.6k
Cheers.
did you find out how to do this ? i need to know cos mine is the same.........
Me and a mate tryd this ages ago..... we sorted it in the end. THERE WAS A WAY TO DO IT. haha
but i can't for the life of me rember, i'll have a chat and get back to you guys. :thumbsup:
help lads
ere you go then
put the key in the lock and on the back their is a clip that hold it in , slide the clip out and the barrel will come out and you should now be able to get the lock out , still a bit tricky tho , and the clip can get corroded in
good luck lads :thumbsup:
or you could just get a haynes manual? i got one for my 9n wen i needed to take the boot lock and handle off for spraying!
when you remove that clip that holds the barrel, its hard to fit it back in with your new barrel. i gave up.
read this and still cant get the clip off
Cheers.
i have the same problem can someone in lighten us, i know your meant to put the key in the lock and remove the clip at the back to remove the lock barrel but can remove that its nackered corroded HELP!!!!
