Polo 1.2 Year 02
Hi can anyone give me any idea to what is the problem with it, you can hear the sound from the jet but there is no water at all to the back widowscreen, there is no water in the boot and the frunt works fine. i have also used a small needel to try and clear any dirt within the jet still no luck
with regards
thanks
Edited by killer311271
  • Views 555
You've got water in the bottle haven't you?
these pipes come off quite alot,
check inside the mechanism through the boot.
and if thats clear I'm told check under your rear seats.
oh actually yours will be the mk6 so I'm not sure if this is the same as my mk5, but try it anyway!
