Mk4 1.4 8v Starter Motor
I've got a starter motor i bought for a 1.4 8v mk4 I'm sure it will fit others though but you will have to ask on the forums to make sure.
its used but in good condition and I've tested it and its in full working order
Reason for sale is i bought this thinking the motor was broken but it was was my starter switch not the motor that was broken.
£25 inc postage.
EDIT: it was from a 68k mile car.
Edited by EthanMk4
  • Views 178
£20 inc postage?
U still got this by any chance m8?
and do u know if its easy to change ureself or is it a job for a mechanic? :lol:
cheers Sam
Edited by SamJ6n
You can do it yourself, you need a 10mm and 13mm spanner, jack and enough swear words to get it out LOL
Hope this helps
Hi, yea i still have it and yea like Mk4man says its really easy to change you go under the car for one bolt and to take the wires off and you can take the other 2 bolts out from above then back under then back under the car to pull the old motor out then slot the new one in connect the wires back up screw the bolt in then you can do the last two up from the engine bay.
Hope that helps :-)
