Removing Front Bumper And Wings Mk3 Polo
are these both bolt on? do the wings remove with ease?
cheers
  • Views 4.7k
both are bolt on yes
Bumper: 3 bolts under grille,2 under number plate,2 in wheelarch area holding arch liner
Wing: bolts in row on top of inner wing, a couple behind bumper,and two hidden behind arch liner facing door hinges (Usually covered in underseal unless its been off before)there may also be one in the sill facing upwards but i can't remember exactly.
Cheers Pettsy ill get on it now tonite :)
WORD OF WARNING
when removing mk3 wings take the black wheel arch liners out then tackle the 3 bolts inside the wheel arch
however these can be a pain in the arse as sometimes they are coverd in putty and seelent stuff so your 10mm wont fit on till u av picked it all off
then once ou have the top line off as well make sure your side repeater is out (be gentle or you will snap the plastic leg off) the pannel maybe seeled to the body with lodes of gunge and crap
but aslong as you take your time and get a heatgun aka hairdryer on it to make it go runny you will be fine a metal ruler could be a useful tool to use too (its longer and thinner than a chisle)
ps the above probably wont make sence until you crack on with it
but let us kno how you get on eni ways
good luck 8-)
