Changing Front Indicators On A Mk5?
Sorry if this has been posted a thousand times, Been having a littlle look and i cant quite see how them come out. Has the front bumper got to come off or is there an easy way to whip them out?
  • Views 871
open bonnet.
theres a pin on the indicator (in between that and the headlight, got a flat black plastic head)
pull that up, slide indicator towards front of car, disconnect bulb.
then do the reverse with new one.
theres springs on the drivers side what the hell is that about :lol:
the clip i said to lift up holds the spring on.
you lift the clip, it releases the spring.
right gotcha cheers mate
