Removing Polo Lettering!
hey
was jus wondering how difficult it is to remove the polo lettering off my 6n2 gti?
saw another gti at dubfreeze without it & thought it looked good, would keep the unsuspected
guessing when i flew past em lol
any help would be great ta 8-)
  • Replies 9
  • Views 1.5k
^^Is that the reply you give when you doint know the answer?
Ok stil new to all this
lol.. just get a hair dryer or get a bucket/bowl of hot water put a cloth in it the squeeze the water out and use the steam to soften things up then use a credit card to peel it off.
then rub the black gluey stuff off
wicked cheers for that!!!! :-D
ill give it a go 2moro
if there is still some black stuff on there u should buy a toffee wheel off of ebay they r like £3.
u put them in a drill and it flicks it right off.
I find using a normal pencil rubber works for getting the black stuff off!
Or just use warm water and a microfiber and stop being a lazy nice person and put some elbow grease into it? :badgrin:
You can use the hot water to melt the adhesive or a heat gun on a low setting then us just a car or you fingers to pull off the lettering. then with the leftover adhesive you can use WD40 on a cloth and rub it for while(takes some time but everyone has WD40 lyin around) or use G3 compound polish which will take it of and remove any light scratches you have made whilst doing it. :-D
Thats a good idea il have to try that when I'm removing my side strips :-) cheers
If you use a heatgun or hairdryer make sure you don't hold it too close i made that mistake and melted the paint.
