Help - Does Enyone Know How To Remove Mk3 Windows?
i need all the windows out for the re-spray but 3 bruws later and a lot of effort i only have mannaged to get the side windows out. :-(
i think i can manage with the windscreen as it looks very simalr to the 2 rear side windows but i have no idea how to get the back out or the little triangular door ones out.
can any one give me any tips?? doos donts any thing that may be of help is welcomed!
cheers guys
Edited by joshdawson
  • Views 987
bump!
come on some one has got to have something
Rear screen needs taking out with a wire saw (or a brick) because it's bonded.
Front quarters, undo the screw in the top of the bar, take the door card out, undo the 10mm bolt towards the top of the door in line with the bar, then the window pulls out backwards.
cheers yeti
for the windscreen, I'd just cut the seal with a stanley knife. Obviously you'll have to then replace it but you're unlikely to get the screen out by just pushing it, it'll more than likely break, it's not flexible like the rear quarter windows are.
