Boot Solenoid Fitting And Handle Smoothing
Hi, was just wondering who has had their boot handle smoothed and had a boot popper/solenoid installed and how much it cost them?
Just trying to get a rough ball park figure into my head.
  • Views 1.3k
both my doors are on door poppers and my boot. the two door popers cost me 14quid with postage but i got them on offer and the boot one about £5 they are realy easy to wire up and  mount however...things to watch out for are: make sure that before you buy you know exacly where you are going to put it.- it must be parralel with the latch and you may find that the cheeper solenoids are too big to mount and allow the boot card to go on properly.also watcho out for the rod types.
--some use rods to transfer the linear motion where as others use wire. apparently the rods are more secure but personaly ithink they are a pain and utterly usless unles its a manafacturers part so my advice- get a cabel one just make sure it secure when you fit it otherwise that will piss you off. (you may need the to modify the latch retanating arm to ensure the cable wont come off) when wiring up simply earth one to the boot and run the other in tandem with the rear heating element wire.most kits to buy dont cost much and come with everything you need and some are even fused so less chance of you braking it.i would recomend this one:
http://cgi.ebay.co.uk/BOOT-DOOR-BUTTON-POP...A1%7C240%3A1318
or if you do wont to go very cheep then you could try thisits a central locking motor and it will do the same job for a lot less money but i have had a spot of bother trying to get this to fit in the rear of my coupe and you would probably need a bycical brake cabel and a wire locking thing out of a plucg socet and a lot of pacience i have 2 of the above and the one below for the boot but the one below realy was a lot of hassle
http://cgi.ebay.co.uk/2-Wire-Central-Locki...A1%7C240%3A1318
hope this helps jack 8-)
Edited by joshdawson
Lol, thanks for the help mate, but you kind of missed the point of my question.
I was wondering how much the actual smoothing of the handle and installation of it to my boot would cost at a bodyshop :)
