Distributor Help
I have 3 wires going into my distributor (my polo is a MK3 (like this))
Brown
Black
Red+Green
The black i have identified as the earth, what are the other two? As I am looking to put a switch in the positive, and hide it somewhere, to prevent my flatmate from taking the car without me knowing...
Thanks in advance
G
  • Replies 8
  • Views 888
u realy need better flat mates if you are thinking about this, if u are going to put a secret switch though i would put it on the LT side of the coil pack
a good hard punch in the face should remind him about taking other peoples cars without permission
Why dont you just not leave your keys hanging around?
You are obviously living with a tit though, not a mate.
There's an easier option.
Remove the yellow blade fuse above the fuse box. That will cut power to the fuel pump. Then all you have to do is refit it when you want to use the car.
Just keep your keys with you lol or let him take it then report it stolen.
Or just take the king lead from the coil to distributor, and hide it somewhere.
Or unplug hall sender or coil plug and plug it back in when you want to use it
Or leave no petrol in it and have petrol can hidden for when you need petrol
Possibilities are endless :lol:
fuckin tie the cun.t up n pull his ears off. he'd be no flat mate of mine pal.
takin the fuse outs easiest way init.
WTF man :?:cry:
