6n To 6n2 Questions
hi , wondering if anybody can tell me if the door cards out of a 6n2 interior will fit into a 6n , and also what is the defference in the tailgates ?
  • Views 960
rear door cards will definately, fronts need to be altered. as far as I'm aware.
not sure about tailgates...
tailgates should fit..with slight modifications..try searching on the forum for info..
The boot will fit right on with no mods if i rember right as i think his name was mike on here with a baby blue polo 6n did it and said it fits right on with no mods if i rember right
Tailgate will fit but won't line up along the bottom,. It won't line up with the part of bodywork underneath the rear lights just as the 6n2 rear lights do on a 6n.
As you can see the rear lights stick out so the 6n2 tailgate will line up with the lights but not the bit underneath the lights, so you'll have to build the bits out.
