Polo 6n Under Tray
Can you get under trays that protect the bottom of you engine for a 96 polo 1.4 6n
If so were and how much
  • Views 1.7k
VW and I was quoted £70 for it! No point really, if your low its annoying as its about an inch lower than everything else so it just scrubs everywhere and eventually becomes usless.
Yup took mine off due to non stop speed bump rampage
just odd metal scrape now haha
On the valver the tray directs air to the gearbox to keep it cool. Not sure if that's the cas on the 8 valve version.
OP
Surely the middle grill in the 16v bumper would do the same job? And its joined to the engine, its going to get hot, some cold air woulnt help much I wouldnt have thought.
I've taken mine off. No problems so far. I've made a mud guard under the cambelt though, mounted just behind the splitter, to stop bit of gravel getting into the pulleys.
The subframe is the lowest part of a 6N.
OP
There is a ducting pipe that runs from the passenger side lower bumper grille, in through the side of the undertray, and terminates in a wide angled nozzle that directs air straight across the bottom edge of the gearbox. Yes, there's probably some air coming through the centre grille, but that has to go through the radiator first, and this ducting is so obviously aimed at blowing air across the gearbox that there must be a reason for it.
oi no wonder why it stinks haha may after put it back on :(
not today tho bloody RAIN!
