What Should I Do With My Polo?
Hi there!
I have been driving my mk2 "squareback" polo (1.3l) for three years now and have loved every minute of it. However I am now doing lots of miles due to my work and have bought a diesel Astra, which is perfect for what I need.
I'd like to keep the polo and have some fun with it but I am not sure the best way to go about it. Ideally I’d make it fast, without changing the bodywork.
A friend has a mk1 golf gti engine (1.6 I think) I can have, but I understand that there is a height issue when fitting them to polos. If I went down this route I guess i'd like to fit twin Weber carbs.
Other than that I could leave it dead straight and let someone else enjoy it, in which case I would probably buy a golf to do up but that sounds expensive to me so thats a last resort.
Just to fill you in from my point of view:
My polo has a couple of problems,
I have the Pierburg 2E3 carb fitted, only problem with that the engine keeps cutting out at low revs when the automatic choke is coming off. (if anyone has a solution to fixing this please let me know).
The windscreen wipers do not return to the bottom of the windscreen when I turn them off ( I believe this to be a relay problem, but when it comes to electricals I have no clue!)
The polo has done about 94k miles
I am capable of doing just about any work necessary myself, although my experience is mostly in motorbikes.
I don’t have a huge amount of money to spend (but that never stops the majority of us).
I would be grateful if anyone can give me advice on what to do, maybe which carbs fit the mk1 gti engine.
Thanks for reading!
  • Replies 11
  • Views 1.6k
Lovely looking mk2 :-D When my Pooburg carb started playing up, I had a friend fit a single Weber manual choke replacement. I wouldn't personally recommend repairing your Pierburg if you want to do anything other than drive it daily :-)
Thanks! Out of interest, what would you guys say a mk2 in this condition is worth? (Its E reg)
WTF? Are you considering fitting GTI engine to that above^???? Best of luck, but I can only think FAIL!
clean looking car their fella , i would stick a gt lump in it 75 bhp stock , then it can be tuned to 100 bhp , their is a section in the top of engine technical forum that is all about doing a 1.4 and 1.6 conversion into these as well
the gti engine is alot of work but you can get subframes to put them in but if your on a budget its not practical
if the cars as good as it looke could be worth upto £500 maybe a little more
go for a sleeper- big lump but keep it looking stock on the outside, maybe lower, and some wide steelies with the old trims on.
What are your concerns? any info is useful :)
Erm, it won't fit! :lol:
it will, with abit of work!
Real clean!
I reckon, slam her, smooth her, 13"x7" wellers, boot build, double front lights, flush black grill blah blah blah.
Maybe wack in a GT lump?
Aha have fun with it mate!
Edited by gregsharp
Give it a whack with the slam-stick, GT or G40, and some RSL Cults.
Thanks for your thoughts guys!
Here are a few more pictures, Ill be sure to show any progress I make with this.
"Please excuse the mess inside"
Edited by Antskilton
