Sorting Out The Mk3 Driving Position...
Right, bought another Mk3 as a runabout, and OMG the driving position is horrific. In my GT/G40 I have cloth Rado seats, and you sit nice and low.
I need this seating position in my runabout, mainly cos I'm well over 6ft and it's not comfy as stock.
How much work is it to get Mk2 GTi or Rado seats into a normal Mk3? Any other cheap options?
I need the low down go-kart gangsta lean stuff going on in my runabout, lol.
  • Replies 12
  • Views 1.4k
Another pair of rado seats is the answer there.
have you lowered the seat. the seat is height adjustable. its 1 of the 2 handles. when i got mine my head was on the roof lining. the height was jammed, much better now
Oh yeah I know, but when I bought my GT/G40, they were already in... now I would like to know how easy/hard it is to get something similar done. :)
you iv had the same problem in my mk2, currently looking for some corrardo seats to sort that out, there easy to fit just one bolt at the front and they slide out backwards, mk2 golf seats are teh same height so youll have teh same problem, iv currently got mk3 golf gti seats in there proper comphy but I'm considerin cutting the subframe down
gt seats or scirocco seats are probably the cheapest option, i have rocco seats in my loon and you sit pretty much on the floor, very comfy too.
rocco seats are lower than the gt/g40 seats i have a set in my mk3 polo
mk2 gti seats go straight in, 1 10mm bolt in the front of the centre runner needs taking out then just slide the seat all the way back and the mk2 seats mount exactly the same way, no problems
hope that helped
Sion
Yeah but the passenger seat is not height adjustable, so you sit really high. Also the drivers seat only goes as low as the stock seatining position. If you look, the subframe it that much higher on the GTI seat. Beware as i made this mistake. Also i put the head rest through the windscreen earlier this year because the passenger seat was too "high"
Good luck!
H&S
I'm a tall boy but fit fine in my gt seats but def keen to get some rocco seats in if you sit even lower!
yer rocco gt2 seats defiantely, low and nice and snug! get a genesis back bench too and they'll match!!!!
Open the sunroof.
Rado seats sit really nice and low, just got a set and bolted them in today. At 6'6" I even fit in comfortably now!
