Mot Prep
MOT is just around the corner so i decided to take a look under the car see what needed done.
coilovers were the onli things that looked shabby so i decided to strip them out and give them a refurb took some before and after pics
before
after
also decided to re-polish and paint rocker cover. decided that last time i painted the lettering it looked naff so i decided 2 inject the paint into the letters until the were flush with the rest of the rocker
all comments welcome
stephen
  • Replies 9
  • Views 1.2k
Didn't realise that was neccessary to pass an MOT?
Good effort cleaning them though, look as new.
Rocker cover paint looks mint.
Well i suppose you wont fail on the car being dirty :lol:
done a good job there mate. you do realize that things cant fail the mot for looking shabby though dont you ha. its the things that look unsafe that you want to check.
some mot testers are really arsey though. They may have said the suspension is corroded or something.
Last year I got failed on my coilovers because the guy said they had to be dry and not leaking anything, even though the substance that was leaking was copper grease which I apply to protect them.
Have a look around the car to see if there's anything that doesn't look right. Have a quick poke around the suspension components - do any of the rubber bushes look like they're deteriorating? Do all your bulbs work? Tyre tread depths, windscreen washer bottle full? If you're on coilovers, is your car so low that its going to cause problems getting on the ramp or rolling road? If so, consider raising it up temporarily. Take it for a short motorway blast just before the test - should help the emissions.
I know that having a tidy clean car sets up a positive impression in the tester's mind, but cleanliness wasn't part of the test last time I went for an MOT. :lol:
cheers guys.
i no all the stuff that is required for mot and everything is good just thought the coilies would look better cleaned.
in cleaning them it has resulted in the anti roll bar hitting the chassis so I'm going to try reshape the chassis to stop the knocking noise.
stephen
Looks very nice spesh the rocker cover looks mint! 8-)
good effort on the coilovers!
bet there not siezed anymore
its unbelievable how freely the nuts slide up and down with the cooper grease.
i have another rocker cover the same if anybody is interested in buying it.
stephen
