How To Fit An Engine Cover?
Hi I've bought an engine cover for my 1997(P-reg)6n polo, I've got all the fittings but I'm having trouble fitting it :retard: A diagram would be great if possible?
Edited by jon H
  • Replies 10
  • Views 1.7k
right, youve got the 2 metal mounting brackets that the cover attaches to right?
no I have got one bracket, I will take some pics of what I've got! supoposedly a full fitting kit :shock:
you should have two brackets, youv got the one for the right hand side, but you should have another smaller one that sits to the right of cambelt cover,
anyway, both brackets bolt into the back of the engine, in the gap behind the rocker cover and the airbox. you should already have two metal things attached here, one with your spark plug cables (lol forgot what they're called) attached to it via a clip.
basically replace these metal things, theyll look like the parts youv bought, but without the engine cover mounting points (the little threaded bits, there should be 3 in total)
thanks mate, so all I need is the left lifting bracket and I'm sorted? anyone know the part number? or have one lying around they can sell me?? :-)
thats it pretty much, local scrappies?
thanks mate, didnt think it would be this much hassle to fit! its cost me £38 in total and its sill not on my car :-(
where does part 4 on the cover diagram screw in to? part 2 replaces part 24 on the engine diagram,but theres no replacment for part 27? I'm confused!
sorry, but where did you get that kit from as I've got an engine cover, but no fixing brackets.
VW mate
