Coupe S. What Parts?
I have a late model mk 1, and i know of a coupe S being broken, What parts are worth getting? Brakes? engine? gearbox? rear axle? ARBs?
Cheers in advance
Boab
  • Views 775
Well they have same engine 1.3s as other mk2s if its an early upto 1985 i think will have the good old revvy HK engine code then deffo have that. later engines asr MH 1.3 hydro head not sure on the latest coupe s probably 2G not bad but early HK much better to have. Oh and the gearbox later has 5 speed 8p code box
Grab the S badge on the boot if its there and the seats door pannels , Steering wheel Speedo with Rev counter Late speck same as early GTs bucket style. Early Coupe s best pattern black and red stripey or black and silver stripey. looks retro cool 8-)
Get the Dash surround with a red stripe around the speedo.
Early upto 1985 have same brakes as mk1s with small pads 239mm solid disks. Late style have 239mm solid disks with better bigger pads.
If it has a steel sunroof take that out.
Other stuff like pannels (if they are in good nik) take off and sell on here get some money back.
Is the coupe s too far gone to repair. shame to see another broken :cry: quite rare now.
Edited by jmk2g40
see if you can fix it up and put it back on the road
All good advice.
If its the later one,remove the electronic ignition system - they go for carb conversions.
Where are you? If you're near and its a later model with cheq' seats then id have the rear bench as i have a fag burn in mine.
