6n Electric Windows
my passenger side window goes up really slow so I'm guessin the motor is on its way out. was just wondering if as 5 door motor will be the same as a 3 door. and if 6n and 6n2 motors are the same ???
anyone got any ideas
cheers
  • Views 1.2k
might not be the motor mate,pull the door card off and check the glass is on the slides.mine falls off from time to time and causes the glass to go up slowly
mine does this too... goes down nice and fast though! sodding passanger side stopped working the other day, still can't find the cause! any ideas peeps, when i press the button, it causes the electricity flow to drop off momenterily, ie beams get dimmer or revs drop but no noise from the mototr or nothing? :-( sorry to thread jack, but this is getting right on my tits! :thumbsup:
I've had that problem with my drivers side one. jus didnt work one day so i had put a new motor in so I'm gueesin yours could have had it too
anyone any knowledge of if the 3 n 5 door motors are the same ???
I got this, loads of people have. If you do a search I'm sure it would come up with a good few threads. There is a link to a DIY guide on one of them to fix it aswell if i can remember rightly
cheers. I've tryed searchin n theres loads of help for fixing the windows which i unfortunatley know about but i cudnt see anythin about differnet motors.
dm tho ill jus strip the door down n compare them. if it fits it fits
ignore what i fucking said then :-)
i was trying to lol oj i had me card off today and checked it out and it was fine, i lubed everthin up aswell to make sure nothing was stiff but its still being gay so ill just leave it till i can afford to replace
cheers for the advice peeps
