Low Entry Jack For A 6n
Just wondering roughly how much a Polo weighs as I'm looking to get a low entry jack and was wondering what weight rating I would need.
  • Replies 9
2 tonner, 15-20 quid sorted
well the 6n2 is like 1050kg so the 6n should be lighter than that. so most jacks should be good
Edited by gtisteve
you are looking at just under a tonne mate, well 985kg for the 1.4CL, not sure how that stacks up against the 1.6GL 5 door
I've seen some aluminium racing jacks rated at 1.8 T with a minimum clearance of 89mm so would be ideal for me.
Usually I make do with my cheapo jack and planks of wood to get it under but it's not a great jack so I thought I'd invest in a low entry one they start at around £80. :shock:
Thanks for weights guys.
heard some bad reports about the cheap low entry trolley jacks collapsing. There was a post on club gti about them, i'll see if i can find it.
I use a 3 tonne sealey trolley jack for mine, would still have to drive it onto blocks to get under if it was lower but as it lifts pretty much all of the car pretty high its worth it.
weights always 2nd line down on chassis plate mate. one under the number. bout a ton n a bit id say though roughly so a 2 ton jacks guna be dead reyt init
My mate bought a clarkes racing jack fron machine mart for just under £100.
Has a roller on the front of it instead of wheels. We haven't had a problem with any car, it just slides straight under!
Deffo worth the investment if you work on a lowerd car quite a bit. I just use the standard car jack untill I can get my jack under
