Battery Tray, Mashed =]
Hello
got wet feet driving home yesterday
looked where the water was coming from and could see the battery =/
took battery out and the hole is HUGE!
Has anyone just patched the hole up cus I've heard its a common problem
or would it be easier to weld in a new battery tray
if so where from?
atm I've just wegded a piece of right angle alloy in and used bathroom sealant to seal it tempory
thanks you
  • Views 707
Yeah it is a common problem, no need to find a new panel just get some sheet steel the same thickness and get a decent welder to weld it all in for you, my battery tray is nearly rusted through luckily the rust is only the size of a 50p to I'm tempted to weld it in myself :) hope i helped?
yeahh thanks
ill get a pic up later but the hole is like all along the one side
and quite big
ill just weld the piece of metal i have in there atm
should be all good
