What To Do Before A Rolling Road Day?
i want to turn up and get the best of what i have at the moment.
was thinking.
change the oil & filter
bosch spark plugs
magnecor ht leads
check my thiming
any thing thats better?
jack
  • Replies 26
  • Views 1.9k
Check all fluid levels and tyre pressures, these are things that should be done but won't increase performance.
New dizzy cap and rotor arm aswell
oh yeah that to! thanks
do magnecor leads better then gsf standard leads. sounds silly but am i just paying for the blue silicon?
Pretty much cosmetic tbh
I've got them on mine, haven't noticed any difference really, they just look nice :lol:
Edit - By the way, start filling up with V Power asap. And maybe replace or clean your air filter.
Edited by Tris
oh really, they have a 10 year guarantee though. so you can keep replacing they for free right? :lol:
haha v power.
get air filter cleaner if its cotton/foam, if its paper, get a foam pannel.
also do H/G if you are capable and your car hasnt had one... same goes with belts.
got a piper cross cone ill give it a clean.
h/g is head gasket? really, i might pass on that.
the belts are all good.
also magnecor are pricey. where do people buy there leads from? europart dont stock. halford dont to!
Not much point in changing a head gasket till it shows signs of failing IMO
Lucozade + Steroids And Make Sure Car Starts :).
Alex
Alex
do i mix that in with the petrol or the oil. maybe both for good measure!
Ha dont fix it, if it isn't broke!
Just do a full service and check the timing
Couldn't have put it better myself :lol:
Why would you need to put new parts in your car that are already working just for an RR day :retard: unless you can afford to shit money or it actually needs a new part, then yeah, don't fix what isn't broken I say! Just give it a wee service
why change it after the damages is done and the head is warped?
i never understand that... matt does his a precaution and hasnt had one fail on a car yet...
The heads dont just warp and die! Its pretty obvious when that is going to happen as the temp gauge will be off the scale. My first polos head gasket was shot and it never once overheated, just used water and oil.
The head will only warp if you keep driving it and its running very hot.
she does need a service. i was told to do it when i got it never had the money to, now i do so shes getting a treat.
i checked the timing today day and the timing mark was quite retarded. i thought the ecu did it all its self.
where should the timing mark be?
thanks
jack
The ECU advances the timing but it has to be right to start with other wise it will advance too much.
Theres a guide on here by minis84 on how to do the ignition timing.
oh right. tis could be a problem.
thanks ill check it out.
Volkswagen dealer. ATM their prices compete with GSF and sometimes they are lower!! The might offer you a selection of leads too.
this would help bring up you are HP figures a bit
haha imported from the hood yeah?
do they do spark plugs to?
You stole that from Olive Juice :disgust::lol:
tracking :)
a little update before the rrd. i did every thing i said i would!
it was running fine and it sooo needed it, but i checked the time with a timing light and it was fine. running at tdc inbetween the timing marks, thats right aint it?
but I'm still getting this! i needed to pull up my pants but yeah!
Edited by vwjack
