Painting Wheels?
I'm buying wheels this weekend for my birthday that look like the wheels below
only problem is..they are yellow! haha
i want to paint them black, BUT I'm not sure about the following:
do I have to sand the old paint off?
Reason being that I thought id be able to use a sand blaster (as you can see this pattern is a pain in the ass to get paint off of) but my friends sand blaster doesnt work, and he claims i can just spray it as is...
or can i throw a layer of primer, and bake it in the oven, then put a few layers of black on it?
do i put clear coat on it?
Help:(
thanks guys:-D
  • Views 868
Heres a really good guide on painting wheels http://www.imoc.co.uk/forums/kb.php?mode=article&k=95
I don't no if you could paint over the paint you probably could but i wouldn't it wont take long to sand just sand just sand what you can and make sure there really clean.
ah mate i did mine at the weekend, should ahve got some pics!
well mine are only steels so i dont know how different it would be for alloys, but i simply sanded down the paint to to roughen it, used something like 600 grit dry first then went down two levels till it was smooth asssssssss, didnt even go down to the bare metal, simply did it to key the surface almost, fucked the primer off out of it, jsut used 2 & half 500ml cans of satin black on all four wheels which was pleeenty
half way through i gave them a little rub when dry to the touch jsut to smooth off any gash spots, then carried on with a load of thin layers, like loooads, bout 10 mins between each coat. took me about 5 hours in total but thats cos i had to mask up my tyres
let the little babys dry over night, & then shoved them in the green house to bake in the sun the next day, stuck em on after a gentle little rub & there lavely
so, dont worry about stripping off all the paint unless your reallllly bothered, in that case i would recomned you piss nitromorse all over them to get in the gaps
then some primer just to give you something to rub smooth
then many many many thin coats
mid rub
bake over night/day
gentle rub
laquer laquer laquer
bake
extra gentle rub
job done
probly all wrong but thats what i would do with those wheels if you want a smooth shiney finish
i simply didnt use primer or laqure cos mine are steels & satin paint so i wasnt bothered
and as all the nerds say 'its all in the prep!'
thanks man:-D
ill post pictures up a bit latahhh
I'm liking you are guide ;) very through!
