Variety on brands + much cheaper than 185/50...
Any opinions?
Pictures?
will probably scrub on a g40 if lowered
had that size on my std g40 and it rubbed, let alone on a lowered one.
I don't think that lowering it 3,5cm will have any problem...
Will it have any bad effect in accelaration/cornering?
If you want cheaper than 185/50, 195/45/14 is a good alternative.
yeah would opt for the 195/45 tyre the 185/50 is an expensive and uncommon size
The only thing that i'm aware of the 45 profile is that is too low and i'm afraid that it will get my rims crooked all the time...
Thank you for you replys...
my next set of tyres for the G40`S going to be 185/55`s as i want to run the road legal slicks`s and thats the lowest profile they come in , toyo 888 come in 60 profile . had this plan for a while and thats why i went for the eibachs 35mm kit . they should fit fine , i`ve got 195/45`s on at the mo and theirs loads of room . also used to run 185/55`s on a breader slammed 80mm rubbed like fuck , but then it was bound to :lol:
