Splitters
alrights guys, seeing the title you prob thought that this thread was "where can i get a polo gti 6n2 spliter from" but its not, i've just order one and wondered if any one knew how to fit them. are they easy?? how long will it take. its going onto my 6n2 so same model.
thanks for the help.
  • Replies 12
  • Views 1.4k
just an update straight forward to put the splitter on. just had to undo to screws either side of the splitter in the wheel arch. then had to use flat head screw driver and pull the old splitter away from the bumper. new splitter pushs straight in and then just done the screws up. job done. took about 20 minutes. worth getting a gti splitter. looks much better
I've had mine almost 2 years now and still never got it on properly on one side. Doesn't reach round, and seems that I'm not the only one with this problem after seeing a few more like this today at UD.
should fit on mate i thought that when i put mine on it didnt reach round properly but with a bit of force it does go on, i used a block of wood to push the bumper out a little and then just banged it in if u like. tight fit though
they do go on with a bit of pull and pushing the last clip was the pain to get in :-)
How much was the GTi splitter and would it go on 8v 6N?
mine was 48 quid inc VAT. ermm should do i think share the same chassie, ring up main dealer and they will be able to tell u but dont se why not. they are clipped in so if you take your one off now and see if the clips match up.
Hi there,
Did you just go into a VW dealership and ask to order one in as i would love one for mine but got told they were £65.
If not, where was it from.
well just rang up vw in northampton and they said we can get one in for you in 2 days and they're 48 quid payed for it over phone picked up on the saturday, fitted on the sunday. 65 quid is bollocks mate. ring around a few vw's around you.
you can get them on straight,
for ease, if you get someone on the other end, and pop it on in paralel, it fits straight, if that makes sense?
either that, or go from one side to the other, then hold & punch the splitter with the side of the fist (home made hammer) till it gets that last clip on ;)
its hard writin instrucstions
u think that was an easy fit, try fitting a vr6 splitter.............. nightmare
dred to think. how long that take u?
