How Do You Fit Mk5 Red Rear Lights On To A Mk4 ?
I just keptted drillin till it fit
And the blue arrows are that i sand abit of them of to sit a bit more flush to the body
And what photo do you need mate
Oh right did you drill all the holes or just the 1 in the middle ? Probarly photo off the back of the light and how it sits inside if possible ? also what screws or washers did you use ?
  • Replies 53
  • Views 22.1k
  • got a link ? :) thinking of doing this but as I'm a total noob don't think ill be able to pull of the bodgey wiring also what sort of tool do you need for this
Pink arrows are to show were iv sand & the arrow with the blob is to show were iv sand on the coner
The blub arrow is to show the middle nut were iv sanded it alittle
The yellow blob is to show alittle more of the top coner were iv sanded it
The red arrows are to show the ofter hole that i have not drilled out
The blue arrow is to show the middle 1 wich has been drilled out
The red arrow points to the nut that i use for the top
The yellow arrow points at a washer and a nut i use both on the middle 1 to hold it in as iv drill it out to make the light sit back more
& The gray arrow point at a washer this 1 is used 4 the buttom *Only use a washer as i lost 1 of the nuts*
This is to show how they sit not flushed flushed but they will do me better then they was
Do you have any probs with water getting in at all ?
Noo not at all
Noo not at all
Thats great mate I've manged to get one on them actually sitting in probarley lol .. going to do the other 1 2mro .. but yeah its actually really hard to get them flushed man .. mines like yours but i agree with you looks better now :-D . Did you put that bit of like seal back on when you fitted the light on to your car ?
Noo not at all
No i lefted it out just make sure you that you put the nut back on as hard as poss so water cant get in
awesome thread dudes, iv been meaning to do mine since i put them on about 3 months ago! might get them done this week now!
Any think you need just PM me
WAA HEYY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Right finally got my 6n2 Rear's on today :D got home early from work all working as should be :D
Thanks alot Po*Low* !!!
No worrys mate glad to help
Thanks! Very useful thread- fitted my 6n2 Rears today! :)
Here mine Fitted :)
Looks good mate
Hope this helped you mate
And 5 Door :-D :thumbsup:
  • 6 months later...
ok so i've got them flush and chppoed wires on the left and right but still got this disco going on lol
Sorry to be a pain but some one just put it in one message as simply as poss lol all this reading doing my head in :lol:
Will
Are They both having a little disco ?
left side: swap wires 1-2
right side: swap wires 4-5, cut the two lugs off connector, turn connector around and plug in so it's technically upside down from original position, should work now.
  • 9 months later...
Any body got clearer pics of the wiring as i really dont fancy fooking my new lights up. :?
Hella actually make adapters to do this for you............
Did all of you sand down the clips?
I just used a tool to push the wires out and then swap them round. Easy.
Will
Have you got them sitting really flush? I spent ages sanding and cutting bits on one, trying to get it sitting flush, but whatever I did, didn't seem to make any difference! Drove me crazy! Have you any pics showing how they fit and what bits you sanded or chopped?
also what sort of tool do you need for this :D
Edited by 6n Easty
anyone ?
edit: dont worry all sorted actually piss easy :)
Edited by 6n Easty
what tool did u use to push the wires out of the conector? it seems a lot better to do it that way instead of cutting and bodging
If you Crimp the wires and take your time and dont do a pikey job with tape, then there will be nothing wrong.
I just used block connectors and mine work perfectly :)
