I've Really Gone And Fucked It Up Now ...
only had the car on the road 3 weeks and i've been having a real time of it , first it was the smoke from the exhaust,then the o2 sensor,then the oil from a leaking gasket,then the new plugs and carb cleaner for the oily intake... and now it's a clutch bearing...
only noticed this last week at a set of lights and it appears the noise disappear when the clutch goes in,so i called into the garage that fitted the motor and i've been told i need a new clutch,so i take it the bearing and clutch are together ?
but i don't know what to do,it was jumping out of gear today on the motorway and i asked could this be part of the bearing giving up the ghost and he said maybe but it it's not then it's a new gearbox needed ,or at least a reconditioned one .....
price for the clutch getting fitted £210 all in,thats labour,oil parts etc, i don't know if thats pricey or not but what scares me is if i go ahead and get it fitted and it turns out that the jumping out of gear and whurling nooises means the gearbox is away then i can't afford £300-500 for a recon-ed box...
so what can i do ? is £210 for a clutch getting fitted too much ?
is the noise ,jumping out of gear and whirling noises going to stop if i fit the clutch ,or should i just cut this one loose and part it out on the bay ?
why not get a clutch i paid 50 quid then a 2nd hand box and fit it yourself it not really that hard i did mine recently , even a complete novice should be able to do it in an afternoon, or i am shure someobody local of here would be willing to give you a hand
just search the cars breaking section on here, i got my gearbox for £70 second hand, priced up a new clutch for £80 which i ended up not needing and it was £150 fitted at a garage. so for less than £250 you can get a gearbox and have it fitted and having a clutch fitted at the same time will add nothing to the labour.
Yeah,they've got to remove the gearbox to fit the clutch anyway.
I've put a topic up somewhere explaining how to fix it if its only 5th gear jumping out.
mikey if you could I've me a link to that it would be great
I dont have copy and paste on this phone,but if you go into the engine/transmission forum,then go into the FAQ section at the top of the page,its on the first page in there.
I now have a photo,but there's no upload link on the reply page.
