Stupid 6n Polo
getting fed up of having to charge my battery if the car is not used for 4 days or so wonder if the alarm is draining the battery? have noticed that when the battery is freshly charged up the car fires up straight away but the next day or so it takes a bit longer to start up
  • Replies 9
  • Views 1.2k
maybe need a new battery?
Probably is the alarm. I had an alarm/immobilizer on a car I had a while ago and the battery would be flat f. Didn't use it for a couple of days!
connect a trickle charger to battery when car is not being used or fit a battery cut of switch so you can disconect battery where its laid up,
Yup trickle charges are pretty good to be honast, i use them on my motor bike when i dont use it over the winter perioud, although you could have weak celled battery.
well the alarm is a vw fit one. Think my mate has a spare solar powerd trickle charger i could use. might have to get another battery when i can afford one
I would say more battary or something else than the alarm because I've got a alarm and could leave it with only starting it once a week and was fine. You could try turning the alarm off? see if that makes a difference.
i have exactly the same problem...
4 days max then its flat as a fart.
I've bought a brand new battery, and it's still doing it. Mines fitted with a clifford alarm which has been on since the first owner bought it in 1997. Its turned off (well, in valet mode) and its not made any difference. I also have a clifford flashing sticker but I've took the fuse out of that n it still does it.
Its driving me nuts.
All i can think of is that somethings trickling power out the battery via a bad earth or something. or the alternators fooked.
ANYONE HAVE ANY OTHER IDEAS?
cheers
well got the car on a trickle charger now will see if its any difrent
Let us know how you get on dude.
