1.6 8v Engine, Box And Drive Shafts
1.6 8v was a good engine that was regularly serviced but head gasket went, so free to a good home
1.6 8v geaar box out of a 6n polo good condition with no grinding or any other noise £50
pair of driveshaft for a 1.6 8v may fit others £15 per driver shaft including inner and outer cv joint
parts located in evesham worcestershire
any questions plz phone me on 07979294621
Edited by bentheboffin
  • Replies 14
  • Views 382
is it an aee motor?
would you consider delivering if i payed for the engine??
where are u located mate?
LEE
LEE
ok i just c u put it :oops: sorry mate
LEE
4 gear fred i believe it is an AEE motor but wouls have to double check on tuesday for u
mk1polobladei, f u can find a courier that would take the engine then u can have it that way
Helo mate,
Very interested in the gearbox..
Could you tell me if its a single rod change or the two small rod change linkage?
Picture of the box would be ideal (especially where it connects to the linkage)
Helo mate,
i can come pick the motor up anytime u like assuming that it is the eversham near stratford on avon
Helo mate,
yes it is evesham near stratford upon avon
will have to check gearbox in the morning for u
you have pm
Helo mate,
you have pm
only after the motor no gearbox as a project ready to put in my mk 3
oops dont know what happened then
4 gear fred ill yet u know when I've pulled the motor oot of the car
adam randall ill get pics for u tomorrow u also have pm
Hi, I'm interested in the box and i can collect tomorrow. I just need to know if it is the twin rod box please. Thanks
Twinny2,
Let you know i had the box off this, it was a single rod.
However i have a twin rod box if your interested, off a 1.4 8v.. did have it on my 1.6 for a short while! let me know?
cheers Adam.
hi adam, i am interested in the box. i have sent you a msg. thanks
hi just wondering if you have still got the motor
