Black Bits Behind Front Windows Mk3
On my M-reg MK3 Genesis (Coupe), between the front and rear windows there is simply the car's body and paint (as below)
On some MK3's (also Coupe) I've seen on the web this black thing is present between the two windows...
Anyone know the reasons behind this difference?
P.s To get the photos above I've cut-up some existing posted photos to hopefully only show my point. Owners - I hope you don't mind. If you are, just PM and will remove them.
Edited by cheys03
  • Views 1.2k
Bumpty bump bump
its to do with trim level and specs,
All GT/G40s seem to come with them
the boulivard version is my personal favourite as it says "polo" in tiny writing all over it
early models seem to mainly have a plastic version with fins that looks a bit suspect in my oppinion.
the smooth vinyl suits certain colours more than others. i.e looks ace on red cars.
saloon/coupe ones are different from heck ones as heck have a longer panel there (which is why rear door cards are different also)
hear some people say its to make it look like 1 piece of glass or smoother to front and back.
most of them are obsilite or stupidly expencive from VW but DKnight makes repro one which i hear good things about.
i would just keep your paint as if you install it badly its just a big water trap.
Edited by genesisGT
Aha! Thanks for the comprehesive info :-)
cant tell whos cars you've used so you should be ok. Think Dknight sells the bits for £17 + p&p?
