1.3 Coupe MUST SELL!
EBAY ITEM NO. 170359557333 starting as of 7.30pm friday
Important bit!!! Suffers from intermittent cutting out, usually a stutter, though has cut out completly a couple times, suspecting fuel pump as it occurs when I put my foot down, but I've put too much money into this car and don't want to go any further.
Car is driveable, and I've done a couple thousand miles despite the problem and not had to call the AA out so I hope it'll get you home!
He's a 1.3 CL Coupe
91 J reg, 80,000 miles
Mot till may 2010! Tax till October
Only advisory on the mot was a bit of play in the steering rack.
He's a very clean car underneath, apart from the oil you see under the manifold, just a stain now, but oil leak was a faulty oil pressure switch and was replaced.
Body work is average, your usual small dings here and there, aswell as medium dent below the driver's side rear light, and one on the passenger side front wheel arch, plus a spot of rust on the same wing which I found when I de-trimmed the side of the car, which is the only spot of rust I can find! And a spot of debadging!
Previous owner had fitted 6x9's in the parcel shelf, which were blown and so I replaced it with an unmolested shelf and bought new speakers, alpines front and rear fitted to the factory mountings.
Interior is fairly good condition, gt clocks, all the usual quality noises, and a few scuffs on the rear bench where my bmx has been in and out but no nasty rips.
Now I have no reciepts to back this up, but:
At about 70,000 miles:
Replaced headgasket
Waterpump
Cambelt
Fanbelt
Distributor cap
Plugs
Oil pressure switch
Coolant & oil change
Air filter
And less than 5000 miles ago:
New battery
Coil
Coolant temperature switch
Fuel filter
Rear brake cylinder
Plugs again
and ht leads
Car is on ebay due to start at 7.30pm, ITEM NO. 170359557333, car is in Woking
I don't know how much money to ask, but would love 300 quid, and open to offers
07875635445
Edited by Radnuts
  • Replies 18
  • Views 1.3k
T+T M8
T+T M8
Sorry?
he means tax and MOT
Ah, cheers, tax and mot both run out in may, but will be renewed before sale
My 17th birthday is in may so i am VERY VERY interested! please pm your number :p
hello mate you still got this? got cash waiting if tax and mot are done.
Edit! Anyone interested?
No interest? Car is running.. just it's running shit and a little more thirsty but if you're in the know then maybe not a big problem?
I'm Interested. Where are you based (specificly).
I'm in the SW of England, near Bath :)
Woking!
SOMEONE GIVE THIS CAR A GOOD HOME PLEASE
If it doesn't go it'll be scrapped or banger raced as I do not have the room for 3 cars, please help!
Do you have an idea on tread depth on the tyres?
I notice on the eBay listing it's got T&T now...any advisories on the MoT?
Says here too, mot till may 2010, tax till this october, advisory was play in the steering rack, went through fine otherwise and then the problem started!
Sorry, tyres look good, plenty of tread, check depth later
Thanks - depths would be appreciated
Got a lil confused over the T&T as earier you said they run out in May...and that you'd renew both before sale...and now it's taxed til Oct and MoT til May...
May give you a call later to arrange a viewing tomorrow if convenient
Yeah, that was the case, but I didn't get rid of the car and so taxed and tested and kept it.
I had to change the fuel pump relay recently as the pump wasn't working, previous to this the fuse went, so as it's 'kangarooing' I'm thinking the fuel pump is next, but the motor factors say it's about 110 quid plus vat so I've drawn the line, it has to go!
Just checked the depths, 3 corners about 3mm, front left about 6mm, so maybe not plenty but enough
On ebay only 20 mins to go!! Anyone?
Clicky!!
