Mk2 Derby Lights
the square ones I'm thinking about geting some but can you still get the fixings and adjusters??
theres 1 fixing and 2 adjusters on each light.
iv tried euros and gsf and no luck, is there any other model ones that fit? like jettas?
Edited by AdrenalinSeeker
  • Views 891
They're mk2 derby specific sadly.
so no way off getting them?
so what do you do if there broken? just bin em?
What do you mean exactly? Do you have a set of derby lights already with some knackered adjusters? Can you not pilfer the plastic bits (I assume that's what's broken?) from some round lights? The Metal braket that the holds the light on the car is the bit that's specific, but the plastic bits and the screws should be the same because the light will be about the same depth.
ok cheers ill have a look when i get home.
