Mk4 Polo
Just wondering if anyone can help.
I have just bought a mk 4 polo, its not been used for a few months starts first time, only thing is the throttle is quite stiff.
Is this common fault?
Does anyone know of a fix?
James
  • Views 765
hi mate,give the throttle body a good clean and check that the breather hose is not blocked,do this by giving the engine a few revs while your hand covers the pipe,you should feel the pressure build up and escape when you release.other than that you should suspect the throttle cable
Should think the throttle cable needs some lubrication with some WD40.
