Mk4 Polo Cutting Out
Got a mk4 polo not lon ghad it and on way to work this morning when sat at traffic lights, the engine just cut out like it had stalled.
Anybody got any ideas what this could be?
It wudnt do it if i kept a bit of throttle on.
Thank you
James
  • Views 1.4k
engine temp sensor?
Thank you
James
My first mk4 used to do this, the revs just splutter and the engine cuts out at junctions etc? It was the servacuum pipe.
Dirty throttle body??? Take the air filter box off and have a look down at the butterfly valve, if its all dirty and sticky give it a clean up with some carb cleaner.
Thank you
James
Yer its doing that only cutting out when its cold, how do you fix it? is it expensive?
Like said before, clean the throttle body.
I had a mk4 that did this. It only took 5 minutes to clean an then it and it was fixed.
Either that or replace the vacuum pipe.
