Slightly N00bish Question.
You have two Mk3 Polo Coupe's next to each other, both CL shelled. One of them has a 1.3CL engine, one of them has a 1.3 GT engine, how do you tell them apart?
Any help is appreciated.
  • Replies 11
  • Views 1.2k
Different airboxes?
That the only difference?
Usually the first sign if both cars are standard is the badging, the CL will just say "POLO CL" on the back and the GT will say "POLO GT". The GT will also have a GT badge on the front grill and the VW badge on the front grill will be black and the CL's will be silver.
Bodywise the GT will have black arch trims whereas the CL wont and GT's bumpers usually came wil red trim tape in the little groove on them.
Inside, the GT will have better bolstered seats, a thicker, nicer looking 3 spoke steering wheel and a rev counter.
The GT will also have black headlining.
The best way to tell though...either look under the bonnet or the best bet is in the boot to find the little stocker that gives details such as colour code, engine power in Kw and engine code. If the code is 3F then its a GT, if the code is AAV or NZ then its a 55bhp 1.3.
Hope that helps :lol:
from what i have seen, the CL has a glass roof that i think doesnt slide, and gt has metal roof that does...
a mk3 fox/genisis i had, had a metal sliding roof
PMSL.
Sorry guys, you've not read my post properly.
Basically, what i'm asking is how do you tell the difference between just a normal Polo 1.3 CL engine, and a Polo 1.3 GT engine. Not the actual cars. lol
look for the MPI manifold(4 injectors instead of one), the airbox, but there was a CL with MPI also, so check the block for the code
probably best checkin the airbox a cl may be single point injection which will have a big black flying saucer looking mother over the carby injectory bit and the gt has a rubber elbow ladint to a pipe which in turn leads to a cubiod airbox. if the cl is lucky enough to have a nz it may have the same intake set up though in which case your knacked unless you can get to the engine code easily. hope that helps
Cheers guys, pritty much what I was looking for.
both CL shelled.
Basically the airbox if they're both standard engines, the engine code should be stamped onto the block aswell.
Yeah the big give away is the frying pan air filter box on the 1.3 spi engine (cl) The Cl might also not have a rev counter.
