Help! Ticking Sound
hi all I've got a ticking sound comein from around my exhaust manifold/ rocker cover!! can anyone tell me what it could b??
  • Replies 13
  • Views 1.5k
low oil probly
Hi Azza,
Well assuming you have a 16V then this will have hydrollic tappets. As stated before, check your oil level.
If your oil level is fine and they only 'tick' on start-up with a cold engine and go quiet after a few moments then that's normal and nothing to worry about as it takes a short while for oil pressure to build up and reach them.
If they tick all the time then they need replacing and cost about £8 per tappet.
It's possible that you have a tiny hole in your exhaust manifold which could create a similar effect but I'd suspect the tappets first.
Si
Hi Azza,
Si
klkl you checked oil level and it was ok so like u say its most props the tappets r they hard to fit??
if you dont know what your doing...dont have a go. the cam has to come out and putting it back on you will have to time it up correctly!
garage job, it wont be that expensive
[/quote
can i still drive it or will it make things worse??
it'll just annoy the tits off you
it will get worse. as in louder
ooo g8 I've got no cd player so i carnt cover it up!! get it dun next week wen it go in 4 a full service!!
sounds as though it has been clocked :smile:
Sounds more to me like the exhaust manifold gasket is leaking.
Carbon monoxide poisoning will give you a day to forget,so get that checked sharpish.
sheeeeet... i got the same noise from mine, id think i need new tappet + adjusting
mine ticks after I've been ragging the shit out of it!
but i guess thats the exhaust manifold cooling down haha
Agreed. Wise words.
Hi Azza,
Si
I'd go with this but in my experience new lifters may not work as in the case of mine, motor has done 77,000 miles, fitted new lifters to try and quieten the motor down (had already tried an oil change), new lifters sounded worse than the old ones, recon the reason for this is slight wear in the cam lobes that were bedded into the old lifters, (maybe due to infrequent oil changes) new cam as well as lifters would have been the only solution.
Motor still runs fine but i'm fitting a GT motor soon so not bothered about the noise now
