Stone Chips On My Arches..
Hi guys,
I've got a mark 3 polo and as we may all no my wheels extrude out abit 8-) .. but I've seen some polo's with
as best i can describe it as being, 'a black thing' that goes from the bottom of the arch up to were the arch start to go
back over the wheel.. And I've been told that this stops stones from being flicked up and chipped the paint work around that area? ..
So, does anybody no of were i can get these from, or are they home made or what?
Thanks, Phil :-)
Edited by Polo-Minion
  • Replies 11
  • Views 1.4k
I'm guessing you are on about the rear spats you get on some lower model Mk3 Polos?
You mean the little arch spats that cover the front of the rear arch, they don't go all the way over the top like GT arch trims. I think you can get them from a mk1 golf but I'm not overly sure!
yeah little black arch spats come on lower level polo's
my 1.3 cl coupe had them
but dont look great tbf
Why not use the Mk3 polo ones?? :?
Spats aint gonna do naff all really mate ..
You need bigger arches
^i didn't realise the lower level polo's came with them. Learn something new everyday don't we ay!
hmm, well i got some new rims on the way so hopefully th 1inch thinner diameter they are should sort the problem out abit :D
Cheers anyways but i might keep my eye out for some cos i dont think they look to bad tbh..
Phil 8-)
I've call them banana's ever since the Selecta polo customizer called them that,
When I got my mk2 square one of the rear arches was pretty dented and the 'banana' wasn't going to fit back on so I ended up welding and smoothing them completely. Since then and without mud guards stone chips have started to rust up a bit so I'm planning on spraying some stone chip neatly in the area before painting once the weather improves.
You mean these fellas?
I'm colour coding mine 8-)
^ yes there you go, bananas lol.
:lol:, there even yellow!
