Help: Buying Mk2 Polo
Hi, I need help. I am going to see a MK2 polo this week and need help in finding out if its any good.
What do I need to look out for?
What should make leave?
Where to look for rust/accident repairs?
And what are they like on an everyday basis? thirsty uncomfortable ?
Any reliability issues?
  • Replies 10
  • Views 1.6k
ooh thanks, this is what I was looking for, this is very helpful.
nice choice of polo. rust is the thing to look out for and that just down to the age for these wee cars. the engine's are very good and should be no major problems.
Look at where the battery goes
the petrol tank (the pipe that runs from the petrol cap)
The bottom of the doors and the black window runners
If it has the black arches trim it can be pretty bad behind them as they hold the dirt and some water some times.
Check for rust underneath the battery tray, if there is (more than likely) than you need to check in the drivers side footwell. Remove the lower part of the dash (2 x phillip screws) and look for rust, mine had a dirty great big rusty crack in it which allowed water to seep into the car.
This will need welding up. Check the engine mounts, the thread on one of mine was knackered so I had to replace the whole engine mount, VW sell them cheap.
Other than that a good service, clean the carburettor, oil change + filter, spark plugs, ignition coil, rotor arm and cap.
Mintex brake pads and discs are el cheapo.
Do all of this and there shouldn't be any forseeable problems.
Boot floor
as above on the rust issues...look everywhere and have a good look underneath with a torch
for old cars they're comfy enough to ride about in
try and start it from stone cold and check it starts first time and idles okay when hot/cold ..you might be aware they often sufffer carb problems that are alkward to diagnose properly , alot of people use a weber instead that fixes it for good
I had a weber and it sucked in the winter with the pancake filter and a new hot air feed pipe, in the end I had to make a permanent hot air feed to stop it from dying.
I never had one issue with my Pierburg, some of them are good and some are bad, the ones from 1986 and onwards seemed quite good.
pancake filters are a waste of money...the proper airfilter will be fine in winter if its all working okay on either carb
Maybe you should buy my Mk2 Polo in the for sale section that has none of the above issues :ninja:
what? pancake filter is the standard filter.
