Water Leak Into Boot
After my central locking was playing up I checked the pump and found water in the connector on the pump, also the wiring to both rear lights was wet. I've got 6n2 rear lights fitted. One side there was no seal between the light on body. I've put some silicone sealant around the lights.
Anyone experienced any other causes of water leaks into the boot area on 6ns?
  • Views 997
Check the rear wash pipe hasnt come off
it will be your rear lights. I fitted 16v lights to my last 6n and the pump went a week later. no coincidence.
A good seal with silicone should be ok, and make sure you got them fastened in nice and tight.
My trick is to wrap the pump in a plastic bag as well.
rear washer pipe came of in mine...was like wtf? checked all the seals etc only to find it was something as simple as this...felt like a right nob
