Removing 6n Seats...
Giving the car a proper hoover out and clean today and I'm wanting to take the front and rear seats out so i can give them a good clean. Anyone got a quick tutorial or tell me how it is to be done.
Help muchly appreciated :-D
Josh
  • Views 839
undo small nut at the front, which usually stops it coming of the rail and slide it back as far as it will go.
job done basically
don't forget to pull the plastic trims off the runners first though.
And getting them back on is just as easy as taking them off presume?
yep, if you have a 3 door it's easier to remove them with the seat back flipped forward.
make sure you line up the handle with the sprung location pin when sliding it forward, you'll see what i mean when you do it.
one thing i will say though is sometimes the runners are full of grease and it marks the carpet when you slide them out.
I'll have a look now, cheers peeps
Right I've done that, I wanna remove the rear back supports aswell, I can see two bolts either side of them but theres metal surrounding them, any ideas on how to remove these ones?
