Help Needed With Rear Seat Removal
Hi all taking my interior out ready for the new buyer. I've changed vw interiors before but I'm stuck. How does the rear bench come out? I've unclipped the side latches but i cant pull the seats out from the bracket in the middle of the car. Any help appreciated as it needs to come out. Its for a 6n2
  • Views 849
There's two kinda clips that neet to be pulled up before it'll come out....
Work just like circlips, i used a flat head screwdriver and some plyers to get em out last time i needed to do something.
i'f all else fails bud, i'll take a pics of what they are for you. 8-)
good luck
i've seen them mate. So they just pull up and out then?
just undo the 5mm allen key bolts, there are 3, one under the seat and two under the boot carpet. the seat should com eout in one piece i would also do this even if you want to split it as its easyer to prise the circlip out.
mintwiththehole1
Edited by mintwiththehole2
