Could Anything Else Go Wrong!?
Right, so over the past 2 weeks, the following problems have all occurred:
Pedal box bracket weld failed
Started over heating
New discs and pads caused caliper rub
Pedal box bracket weld failed again.
Now it may not sound a lot, but let me break down what I had to do:
Had to MIG weld the bracket back in place, which is not an easy job to do on the bracket.
Replaced the water pump as that had gone, replaced the cambelt while I was there, replaced the alternator belt while I was there, replaced the rotor arm as it needed a new one and replaced the thermostat. Still, the car was overheating so took the thermostat back out and it's running alright.
Then I had to fit new discs and pads. The caliper touched the wheel so had to get an angle grinder to the calipers and then get some 5mm wheel spacers.
Then tonight, the weld on the farking pedal box bracket decides to fail again.
I'm rather annoyed now =[
not good, could be worse though
the whole car could have blown up, movie style :)
Haha, I suppose. Although I'd probably find that cool...until I realise i'm only TPFT insurance and then cry :lol:
lol, would fully comp cover movie related explosions?
You see, you'd assume it would. But insurance companies being insurance companies it would include something along the lines of:
"If in the event of a circumstance which is related to movie-like damage to the car i.e. explosions, flips, jumps or anything cool in any way what-so-ever; You are not covered."
:lol:
lol, i read something the other day that your covered if a ufo hits your car, but if the ufo attcks your car your not covered as its 'an act of war'
:lol:
Lmao, that's as comical as the terms of use for Apple's iTunes, apparently you aren't allowed to use the program in conjunction with building or using weapons of mass destruction.
"…including, without limitation, the development, design, manufacture, or production of nuclear missiles or chemical or biological weapons."
"The Apple software is not intended for use in the operation of nuclear facilities, aircraft navigation or communication systems, life support machines, or other equipment in which the failure of the Apple software could lead to death, personal injury, or severe physical or environmental damage."
So remember kids, don't tinker with itunes and lives!
:lol:
just imagine north korea,
'so what shall we listen to whilst building these warheads?'
'oooh, no, apple says were not allowed to do that'
