A Bit Of Help And Anyone Going To Fast Show?
orite lads, on completeing vr6 conversion and getting it on the road, I've found a few teething problems with it.
1. auxilary water pump is fucked
2. alternator is noisy so I'm getting a new one
3. got a bald tyre so ordered a nice conti
4. obviously needs running in
5. few nuts and bolts missing here and there ha
6. slight water leak
7. no 16v hubs (anyone got any)
the problem i have got is that i need a nice cold air feed but cant find an obvious route and a good air intake to buy. there is also too much heat inside the engine bay butwithout ruining the smooth look and putting shitty scoops and wing vents and bollocks in i dont know how to get around this problem. the car is ver fast though if i say so my self and sounds awesome. I've had to higher the back end back up on the standard spiring though and looks a right nice person ha. more practical though. i need an airride.
  • Views 906
picsssss!!!
As for too much heat. If the cooling system was working correctly there shouldnt be. there should be enough cool air coming in from around the grill etc.
Some holes in the bumper may help or something?
ye its all working mate but the problem is that i have smoothed grills from corners of bumbers and only have the main grill under bonet and one grill at bottom of bumper which are covered behind by one huge rad. i can take the headlamp out when going down the strip but for everyday use i need it more cooler ha. and is anyone going to the fast show?
I am :thumbsup: I've replied in the threads in the events section
Are you going in the VR6 conversion? You camping?
ye mate aslong as i get this waterpump and alti fitted I'm there defo. if it means borrowing some cash then so be it ha.
Cool you got a pic? if i see it il come over and have a peek I've never seen a vr6 conversion in a polo before in person.
