6n Window Prob, What A Suprise!
would this be the motor or mechanism?
cheers!
  • Views 744
try cleaning inside the rubbers around the window first and spray a just a little of lube into the channels and that should do it. had the same problem on my last 6n
Could be a mechanism problem, the clips holding the glass onto the runners often break. Easy to spot if you take the door card off.
