Mk2 Brakes.....jesus
i knew they were shite due to no servo but damn i keep thinking I'm going to die :lol:
whats the best upgrade??
can i change my master cylinder??
what calipers are best to go to vented??
max
Edited by polo.6n.max
  • Replies 22
  • Views 3.5k
to go vented you can use vw2 calipers, like on g40's with 239x20mm vented discs and for master cylinder upgrades you could use a 22.2mm one off mk2 golf gti i think
for something abit extra I've heard about using vauxhall 16v calipers with 256mm vented discs and there is the possability of using a rear disc setup off a golf gti although handbrake cable modifications are needed
thanks
will
Here's a thread from times past that might shed some light,
http://www.clubpolo.co.uk/forum/index.php?...+Brake++Upgrade
I've done a vwII caliper upgrade using polo's carriers with brembo vented g40 brakes and pagid pads, I also ended up changing the rear shoes and cylinders because there was a cylinder leaking. I also fitted goodridge braided hoses for a mk1 golf. Gsf supplied the lot with the club polo discount.
In hindsight I reckon just a good service like the shoes/rear cylinders with maybe ferodo pads would have been enough. There's a passat master cylinder upgrade too but I didn't see the point.
At the end of the day without the servo you've got to put your foot down. Mine seem pretty dam good now but not compared to a modern car. I nearly went through the screen of my dad's Almera.
Other thing to bear in mind is if they're not serviced up with good fluid, they won't work so well.
Personally, I think they're fine, you've just got to use then with conviction.
If you really felt the need for a Servo RatSport do a remote one: Remote Servo
Edited by Cymro
thats a single circuit servo, mk2's are on dual circuit aren't they?
i picked up a remote single circuit servo from a mini cooper s by mistake for £35 off ebay
they come up every now and then, but unless your polo is running single circuit brakes is pretty pointless :lol:
dual circuit remote servos are a pain to find, and fairly pricey to boot!
Didnt think of that. lol.
neither did i until after i'd bought the servo :lol:
Polos have dual circuit brakes.
The passat 22.2mm master cylinder won't fit the mk2, you're pretty much stuck with the standard one unless you relocate it. The best solution I've seen is a cut down scirocco transfer bar, which puts the brake master cylinder where it is on LHD cars, above the gearbox, you can pretty much have any size servo you want then within reason, plus a good size master cylinder.
Mk2 brakes are fine with a bit of work. Having well adjusted rears is crucial. Early brakes are atrocious though, get some later calipers that use bigger pads or maybe get some VWII calipers so you can run vented discs. I wouldn't go for bigger brakes just incase they have bigger pistons, which will increase pedal travel.
i keep seeing VWII and VW2 banded about when talking about brakes, but what exactly does it refer to?
the type of caliper. They have VWI or VWII written on the side of them. VWII are the ones to use with vented discs, they were fitted to loads of VWs in the late 80s, early 90s.
I have gone for the Mk2 Golf Gti Disk's and Calipers ..
There is a small amount of travel in the pedal due to the large piston size but with the large vented disk's and pads it stops alright when you jump on the breaks ..
As yeti said just give that pedal a bit of bastard and your mk2 will stop ..
I find without a servo you can feel the brakes working better .
Haha it keeps me awake thats for sure! when i get back in the polo after the 55 plate golf its like, and push, and push more, more, MORE! haha
gna do the mk 2 thing as well i think like stealth says ^^
was it easy mate?
so basically I'm after some VWII brake calipers/carriers and some braided brake hoses for a mk1 golf
then some better discs and pads
the VWII calipers and carriers what are they fitted to?? and most common car to find them on..as i know the carriers are built into the hubs on golfs e.c.t or can i use my existing one
its a g reg 1989 square btw
Yes but you just need the VWII calipers which fit to your squares carriers, well they do on mine and mines a 1989 square too. I got my calipers off my 89 mk1 caddy.
I'll also add that this set up fits standard poverty spec 4.5j steels.
when i first jumped in my mk2 after my 6n i rolled right out the guys drive on the road instead of stopping. i think they're fine though you just need to press really hard :lol:
I sell dual circuit remote servo's and I'll do some discount too for clubpolo members if anyone is interested.
If anyone wants one call me on 01684 298 700
Hope it's ok to post this here.
Ben
Ben
can you post up some info about whats involved in fitting one etc please
Ben
A few options
1, You can drive to me in Tewkesbury, and I'll fit it for you.
2, To do it yourself you need to pick a point to mount it, and then run some new brake lines in.
You need a new one from the M/C to the servo for fronts, then the same for rears. Then out of the servo to a T piece, then split for the fronts and another out from the rear port of the M/C to a Tee then split for the rears.
They can be used on any car, all drums all discs or discs front drum rears.
Send the vacuum to a port off the intake manifold or if you are supercharged or do not have enough vacuum due to a lairy cam etc, I can also supply an electric vacuum pump.
I sell them as just the servo, or a servo and fitting kit which consists of a laser cut mounting bracket, unions and a one way valve.
http://www.skintaracing.com/shop_viewprodu...sp?itemcode=309
Ben
sounds like a good item , but its dearer than the value of my car so i wont be getting one I'm affraid
Yes we mainly do them to split screen camper van owners, they are very good, but like you say they're more than the car. I don't have one in my polo, but they're an option.
dubbus, what sort of discount are you offering ;)
was looking at the ones creative do to use on my bay and they look very similar
Hi there
Could do free postage and packing on them,
They are the indirect ones that Creative have on their site as coming soon.
We've been supplying them for just over three years now. We supply quite a few aircooled specialists with them.
Ben
