To Flush Or Not To Flush?
Was in Halford other day buying carb cleaner as i ran out while stripping and cleaning my throttle body. Noticed some "engine flush" so i read the back of the tin and thought why not as the inlet was very cokey and i thought maybe the engine itself could do with a good flush before i change the oil and filter.
It says just run the car up to operating temp, bung it in and fast idle for 15mins then drain through the crankcase cover (is this just the same as draining the oil as normal??)
Read a bit online and noticed people saying that engine flushes ruined their engine etc....Should i go ahead or is it somewhat dangerous?
  • Replies 9
  • Views 1.4k
I used TEC 2000 on my 16v and it was very good and my garage use the stuff to on all there dubs when serviced.
+ You can get it pretty cheap of ebay.
EDIT: Why dont you drain the oil the normal way?
Edited by kerrly
I presumed thats what you do, but it says on the tin drain through the crankcase? Weird?
Ah they mean the sump obviously as it is the crank casing i suppose.
I've used it all on my engines with only one thing wrong and it was on a turbo engine it clogged the turbo up it sorted it self out after a few hours driving though.
I read alot of mixed reviews about using it though most people seem to get to temp drain old oil fill up with a cheap brand oil run that for a bit then drop that and put your usual oil in.
i put engine flush in my car on friday and one of the lads at work said leave it in over till sat so i did and it seems fine to me not done out to my car , but i av been told it can ruin your engine tho
You should only have it in there for 15mins with the engine running and then drain it :lol:
I wouldnt use it personally, can make the bottom end knock as it washes the oil off the bearings. Its just a gimmick tbh, waste of time.
I'd say just warm it up, then oil change. Has anyone ever had problems with just regular oil changes?
Just run it up to temp then drain the old stuff, upon refilling i pour half the amount of new oil in then a bottle of Wynn's leakstop and i cant remember the other one and then top up with oil until full. No leaks and no noises :)
