Carbs/tb's
Ok i was going to do this myself but thought I've got a bit of cash that i saved up to do carbon fibre cover my dash but changed m mind so looking to put twin TB's onto my 16v
Does anyone know anyone who can do this, London area'sh, looking for someone to put a set of twin TB's onto a Mk 4 6n 1.4 16v.
Any help would be great!
Dan
  • Replies 22
  • Views 1.3k
surely you would need 4 TBs? anyway... tried contacting The Phirm? do alot of PVW work aparently
Edited by xcore
yup, twin carbs or individual throttle bodies?
Twin carbs prefrebly!
That is a very easy conversion if you do it yourself, mechanically minded?
Very, can weld as well which is handy, but when it comes to ECU's and leccy stuff... I'm thick as shit!
If you're going for twin carbs you don't NEED a fancy ignition system - judging by danny_dubs efforts you can run it off the current ignition system (assuming it's not too far off the 1.6 8v setup)
If not you can just put in the ignition loom from a mk2 golf 1.3/late mk2 polo. The rest is just bolt on stuff and jetting/setting up.
Or a standalone system, the most complicated way, but "best" probably
Edited by twin40racer
this something I'm currently looking into while the engines out of the the car,,didnt much fancy the expense and hassle of an engine conversion but have always facied itb's,,a mate at work seems to know his stuff on this so ill keep you updated on what i find out dan.
carbs are rubbish unless you go bike stuff really, webers drop in and out of tube all the time, probably the cheapest option
ITBs are lots better, easier to drive, start and run like a standard car, drive round town etc, although, cost is likely to be around £2500 if you can find an inlet manifold to run ITBs on the AFH (i've got one though, lol) you'll need a fully mapable ECU that will do ignition and fuelling (emerald £600) then the bodies (475 plus vat) inlet (£200 from sorg new) trumpets, filters, fuel rail, injectors, fuel lines, crank trigger and sensors and then mapping!
Why are carbs rubbish? They're far from it and properly set up can hold their own against the newer technology. Bike carbs are a much less proven on car engine option with less know-how on setting up/performance tuning. They don't just drop out of tune all the time like a fair few seem to think. They have been fitted to production cars, so if you want them tuned and then to not have to mess with them again there are measures you can take... Granted ITB's are "better".. but a completely different thing with that extra cost. If you want more go and enjoy tinkering with the car then a set of twin carbs is great.
Maybe i am just carb-biassed?
:shock: Crap!!! didn't ITB's were that expensive.
carbs sound better! :thumbsup:
this may be a stupid idea but i was thinking the other day (dangerous!)...
could bike carbs be converted into itb's?
somehow mount the original fuel rail and injectors into the carbs. i know it'd need remapping/new management and a manifold making up still, but it could possibly maybe lower the cost a bit.
i did have a look a while back at what cars have got itbs as standard (not many!). but i dunno what size or anything id need...
or you could use bike itb's!!! now theres an idea lol
It's not the throttle bodies themselves that are restrictively expensive, it's the electronics and mapping really. ITBs aren't really required until you are running wild cams anyway, they certainly aren't an affordable bolt-on power increase.
Bike bodies have been done before as well. It's only recently that bikes have started to use fuel injection too, so they aren't exactly cheap.
Bike ITB's are still cheaper than any of their competitors... And would be an improvement on even a mildly modified motor!
Bike carbs are normally chosen over twin webbers or dellortoes due to value for money, a whole set up of bike carbs can cost the same as one decent set of webber 45's... bike carbs also offer ebtter fuel economy. However, it is a fallacy that webbers 'are in and out of tune' and are proven quality induction! they can produce more power than bike carbs and sound better... so i'ts swings and roundabouts really!
thats why i was thinking of a set of itbs that use the cars original fuel rail etc. i know it'd still need mapping, but possibly the only bit you'd need to buy would be the housing/butterfly valve etc...
you need a stand alone ECU also, thats 500+
talk to bogg bros... they are based in luton so local-ish, they sorta pioneered the whole bike carbs on cars thing... talk it out with them, they will advise you better than people on here who are either guessing or using their one or two moments of experience with one thing or another (no offence intended, but bogg bros will no more about fuel induction than 99.9% people on here!) :thumbsup:
FYI, cheaper and easier to go to a scrappy and rob a 600 gsxr of the whole gubbins than faf about with original fuel rails and stuff!
bogg bros are yorkshire dude!
really... my bad! I see they are East Lutton, i assumed Luton like the airport... :retard: still worth ringing up and talking too though!
carbs ftw!
might be worth speaking to guys taht are doing my conversion mate. think they have done alot of carb conversion on mk2's
check mv development section on e38 dan.
