How Do I Shorten The Door Pins?
i have seen a few pics of people who have done it, i like the look, i had a look today at the plastic pin bit and wasnt sure how to shorten htem...as I'm not sure if the threaded bit runs the hole way to the top
thanks guys!
any help would be gooooood
  • Views 1.2k
i aint sure but id think you would unscrew them, then sand the bottom part off just enough so they sit flush when refitted and pushing down. Now I'm only guessing i aint totally sure but i would imagine thats how its done.
Original door pin :(
Remove door pin, window winder (if youve got it!), and door handle cover, undo screws behind it, pull off door trim at bottom working round until all clips are off.
Original hole for pin.
Using a round file elongate hole as necessary.
New hole for pin.
Re-fit door card etc. in reverse order, admire new pin!
What you think, Good, Bad?
Ye i didnt want to say anything because i already said it once......
bend the metal rod or shorten the pin itself.
Only thing i say is that if you sit them so there flush and you lock the doors while you in it not going to be good as you will have to hang out the window to unlock the doors lol, iv done thins >.< look like a right terd
thanks for the help guys! :D
