Wont Start Afh Polo 1.4 16valve
well a passed my test today 1st time yay :-D
its not all good went to start my car up and spun over and started as it should then i put a live to the window switch to try and fix the window problem and there working now :-D i then did a few other things to it non electrical and goes to start it and it just spun over
checked fuses everything is pluged in
checked for a spark = non
fuel pump = working but not injecting any fuel
so i got my scanner on it and it came up with > tps sensor signal too low, air intake sensor. tps valve senor, coolant temp sensor
it also said that the coolant is at -40 degree aswell as the air temp at -40 degree
i had the scanner on it a few days before just to see if there was any codes and the wasnt. at first i thought it might be the throttle body but after i checked the air and coolant temps were at - 40 i think its more like the ecu.
anyone have any ideas or had any problems like this.
  • Views 802
any ideas? might be after a ecu if anyone has got one for sale
