Polo Mk2 Battery Tray+rear Light Housings.
Hi, i've just joined the club and am restoring my 83 polo mk2 formel E for my first car.
The first part i have to tackle is the battery tray that has a gaping hole in it which results in soggy carpet :-( , i hear these are prone to it... I read somewhere you can get a repair panel for mk1s and wanted to know if they're available for mk2s? Also if they're available how do you fit them? And if not how do i make a smart repair panel and fit it?
I will be very grateful for any advice as at the moment i am stuck. :-)
Also the same situation of i dont know what to do, the rear light brackets/tabs have rotted :-( , meaning the top tab is the only one holding the lights in. I wondered whether again there is a repair panel available for each side and where?
Again any advice would be grately appreiciated as it soon needs to be sorted.
  • Views 664
Think there was spare trays available from somewhere but to be honest it sounds like you need a plate welded in there maybe drill out the back support that holds the battery first if that's where the rot is. Then you can re-weld that support back in seam seal and then paint. I hammerited and undersealed mine. Either way it would involve some fiddly prep and welding.
Some folk have fiberglassed in there which would work maybe pop rivet a panel in first but this is verging on bodging it. It all depends whether you have a welding facility available or funds?
As for lights seems strange for rear body where lights fit to rot unless the cars maybe had a ding there. It's easy enough to take the light off and investigate. Then on re-fit tighten up making sure the rubber seal is nice and tight to the car body. Pictures would be good to give us a better idea?
Good luck,
